fast hitch implement point size
59FastHitch
02-04-2007 19:59:28
Is the implement mounting point size of the 1 point fast hitch for the cub the same size as the 2 point fast hitch for the 200, 230 etc?
Chad from Michigan
02-05-2007 09:35:49
 Re: fast hitch implement point size in reply to 59FastHitch, 02-04-2007 19:59:28
Well I can tell you this I have a 1956 Cub I bought from the orignal owner and I have the bill of sale to say that the fast hitch is from 1956 as well. With that said I drove by a junk pile in front of a guys house of farm parts he was selling. There in the pile was a 2 point cut off a super C implement of some kind. I gave the man $10 for it and left. I have since cut the prongs off and have mounted them to home made Cub implments for my cubs and those super c 2 points worked just fine. I did have to add the piece of steel that goes up like a tail fin to keep it from moving side to side but other than that it was a perfect fit.
chad
Hugh MacKay
02-05-2007 11:18:12
 Re: fast hitch implement point size in reply to Chad from Michigan, 02-05-2007 09:35:49
Chad: I knew I was right, the very first Cubs used the small fork, same as SC or 200. IH changed the 2 point on the 240 in 58 to large forks. I'll almost bet they changed the Cub in 58 as well.
Nat 2
02-05-2007 05:45:56
No, they are different.
The Cub uses the larger point like the 300/350/400/450/460/560 tractors.
williamf
02-05-2007 03:02:38
About all I know about Cubs is what neat little tractors they are. There is, though, a Web site devoted to them that has about as much information as you can find.
Good luck, Wm
Hugh MacKay
02-05-2007 03:01:37
59: The 100, 130 and 140 use the large fork. I have not looked at a Cub since I saw the first new one in 1955, or there abouts. It had the small fork like SC and 200. Now, I do know what I saw, and I do know the difference.
Having said that, the folks here on YT discussion now tell me all 1 point fast hitches were large size fork. I suspect the small fork didn't last long. The same thing happened with SC, 200, 230 and 240. the first 3 are small fork and 240 is large fork. I've even seen 230s with large fork hitch.
I think we can safely say small fork disappeared by 1958. I'd even bet Cub was changed at same time.
