M Belly pump spec
n9lhm
02-05-2007 05:59:51
Does anyone know what the rated GPM of the M belly pump is? I know the pressure is either 500 or 800 depending on whether it has an 8 painted on it or not, but have not been able to find a flow spec. Thanks, Brian
Janicholson
02-05-2007 07:57:09
 Re: M Belly pump spec in reply to n9lhm, 02-05-2007 05:59:51
After looking at 24 posts on this board, it appears (and from my experience) that they produce about 7 to 8GPM at High Idle no load. At pressure, the GPM will be lower due to bypass at the gears, and builtin clearance. Thin oil will also reduce GPM under load. I hope this answers your question, I have not seen a spec. in a manual. JimN
n9lhm
02-05-2007 08:50:07
 Re: M Belly pump spec in reply to Janicholson, 02-05-2007 07:57:09
Thanks Jim!
