Order Farmall Cub Parts Online
'51 Cub PTO Shaft Question
Michael Sheik
02-05-2007 06:10:18
I am working on Dad's 51 Cub putting in a new clutch and pressure plate. I noticed the splines on the PTO shaft are badly worn and not allowing the pully to tighen down(new pully). I am going to have to get a good used one or go new. Does anybody out there have a good used one and what would I be looking at $$$ used? I can check on new one $$$ at local IH dealer if you all think that is way to go. I am assuming the back plate unbolts and plate with PTO shaft just pulls out the back. Am I correct? I also do not have a service manual and going to look at ordering one today for clutch repair and PTO replacement assistance. What brand book would be suggested.
Rich Griffin
02-05-2007 06:21:01
 Re: '51 Cub PTO Shaft Question in reply to Michael Sheik, 02-05-2007 06:10:18
On my 49 Cub I pulled the pto shaft also. There is a set screw in the pto shift collar that has to be removed first by takeing out the top fill plug and working through that opening. Just my way.
Michael Sheik
02-05-2007 08:32:10
 Re: '51 Cub PTO Shaft Question in reply to Rich Griffin, 02-05-2007 06:21:01
I called IH and they subed the number to a new number for a pto shaft that requires a retainer. Cost for new shaft is 125.00 and retainer is 3.50.
Bus Driver
02-05-2007 16:22:21
 Re: '51 Cub PTO Shaft Question in reply to Michael Sheik, 02-05-2007 08:32:10
There are sources for new ones for less money.
Michael Sheik
02-05-2007 06:23:34
Good to Know!
Thanks
