Farmall C?
Christie
02-05-2007 18:23:35
I have a Farmall Model C at least that what the previous owner told me it is. I'm curious to the year and model of the tractor. Where would I find the serial number to find out the year and model? Is it located on the floor board? The number I found on the floor board is 651132-R1, could anyone tell me the year and model? Thanks
Christie
02-06-2007 16:55:41
 Re: Farmall C? in reply to Christie, 02-05-2007 18:23:35
You guys are the BEST!!!!!
thanks
Christie
02-06-2007 10:35:46
I found these numbers on the seat box 70893d ,on the block FCM 72450 do these help? also found 12.14.T
gene bender
02-06-2007 12:49:19
 Re: Farmall C? in reply to Christie, 02-06-2007 10:35:46
12*14*T Stands for DEC,14,1950 First one built in 51 had serial#71,880
gene bender
02-05-2007 19:28:24
Look under the #1 plug behind the throttle shaft and post the serial# would help to identify.
Patrick in Illinois
02-05-2007 18:44:48
Need to check on the right side of the seat base for the serial number. Will be on a small aluminum plate. If none is there, then we will need casting codes. Example: 10-15-R. Will be on major parts like motor, Trans tunnel, Trans, wheels; most cast parts. Your casting codes should fall within: R-1948, S-1949, T-1950, W-1951. Hope that helps a little. Patrick
