Farmall H Grille
Jim isler
02-06-2007 11:05:40
Hello, friends,
I've just acquired my third IH, an H (FBH141850).
While shopping over two years, I saw that most H's were missing the grille insert. Where did they all go?
I'll also be needing a fan shaft for my A.
Andrew Z
02-06-2007 11:43:34
 Re: Farmall H Grille in reply to Jim isler, 02-06-2007 11:05:40
The inserts where the steerable cultivator arms hooks to the bolster shaft. So when a farmer used the cultivators he had to take out these inserts and most were never put back. Also they are not held in there real well only with a strip of steel in the back and I think it would have even be easy to lose them in the feild or something, if they get alittle delapadated in such.
Andrew
RustyFarmall
02-06-2007 11:55:46
 Re: Farmall H Grille in reply to Andrew Z , 02-06-2007 11:43:34
I don't think that steerable cultivator thing ever really caught on. I think most of the grill inserts just loosened up and fell out, and were then run over by the front wheels. Several of them probably got plowed under.
Bob M
02-06-2007 12:12:51
 Re: Farmall H Grille in reply to RustyFarmall, 02-06-2007 11:55:46
I've found a couple H/M badly bent grille inserts over the years. One I discovered impaled on a low hanging tree branch sticking out of a fencerow. Another I found partially penetrating the sidewall off a plow tail wheel tire after the tire suddenly went flat in the field. (Appears the grill insert had fallen off the tractor and been plowed a year or two before...)
RustyFarmall
02-06-2007 13:58:25
 Re: Farmall H Grille in reply to Bob M, 02-06-2007 12:12:51
Yep, I imagine that quite a few got planted over the years. Don't think any of 'em grew though.
