I'm in love with the H...
Matt Page
02-07-2007 07:02:56
Bought it at an auction for $500. Got took, transmission was toasted, engine made funny noises. Steering shook, tires were bad. The thing was totally run into the ground...oil poured. Bought another one at an auction that had a three point conversion for $200. Had some better parts, some worse. Engine and transmission were both toasted. Tore both of those completely apart, bought another rear end that shifted well on a gamble that it was good instead of replacing all the bearings and some gears in one of the other two. Was totally sick of the whole pile of junk I had piled up and taking up my time, but felt it was a matter of pride and salvage of investment to get it together and get some use out of it to justify the whole thing. Combined parts from all three, slowly fixing everything as I put it together, the best into one...
And yesterday as I was sitting on that spring seat looking down that long hood at the sunset while the engine purred along pulling the trailer load of alfalpha through the cows while my dad fed... dependable and steady. I realized it was in fact a very good thing, and my time had been well spent, and it is a good tractor and a part of history. Even went so far as to wonder if any of the old farmers who had used it were looking down... Heck I'm ready to do another one now. Matt
LenRahilly
02-09-2007 09:25:54
 Re: I'm in love with the H... in reply to Matt Page, 02-07-2007 07:02:56
When I was a kid in the 40s, I thought the H was the most beautiful tractor in the universe. Raymond Loewy's design outfit had come up with a masterpiece. I still think that as a design, it has to be about as good as they come--line, balance, color, proportions, and so on. My father finally bought a used H about 1950, and I agree that it is a lovely machine. But....it didn't have the moxie of the tractor it was supposed to replace--the F-20. The old bird was designed for steel wheels, which waste nearly half the power of the engine. When the F-20 was given rubber tires, it became a real charger; that big engine provided enormous amounts of torque to pull through heavy spots. The H has a much smaller engine, and gets it power from engine speed. There isn't much leftover torque there. On the other hand, the F-20 is one of the most uncomfortable machines ever made--the seat sticks out behind on a stalk that bobs up and down like a see-saw, and there is no good place to put your feet. The H is SO-O-O civilized by comparison. The flat platform is a delight, the seat is comfortable, and the pedals are well-designed. The two slight inconveniences I remember well are the throttle control, which can be hard to reach if you are half turned in the seat to watch a machine that needs monitoring (like a combine or a baler which can clog sometimes), and the gearshift lever, which sometimes annoys the calf of your left leg in low or third gears; also, it may make you bump your arm on the wheel when making a quick shift into the forward positions--unless you develop the habit of turning your hand upside down and "lifting" the lever. The H is a very nice utility tractor, because it is relatively light, has good power, and seems more agile than an
F-20. I used to mow into the zig-zag of rail fences, and found the H about as easy to use as the F-12 we had used before the H came along. A minor drawback of the standard H gearing is that fourth gear is too low for hauling--you often wanted to get maybe 6 or 7 mph on a gravel road with a load of hay or grain, but fourth gives only a little over 5 with the engine roaring at top speed. In fifth, there isn't enough torque to pull a loaded wagon on a gravel at 5 mph. There was available from the factory a 7 mph fourth gear, as I remember, and that would have made a nice transport gear for dirt roads or farm tracks. I always believed that the IH engineers saw a chance to save some money by designing fifth gear as they did--it is nothing more than a sliding dog clutch like the ones used in early 3-speed car transmissions. Oliver, JD and probably others did it right by making 5th do about 8 mph, and 6th around 12--plenty fast for the roads of late 30s and the 40s.
I should add that I loved roaring down the road in fifth gear on the H--it's like being out in the wind in an open race car--but today, when I get a chance to drive one of these tractors, I usually find that there is enough wear in the steering to bring on some pretty heavy shimmying at full-throttle, so it's not as much fun now that I am old and--I hope--wiser.
Well, it's fun to talk about these things, even if it is just empty palaver.
City-Boy McCoy
02-07-2007 09:42:20
Matt: I LOVE those H's myself. Sweet, sweet tractors. And with what you went through to get yours going will make it "all yours" for a long time. Congratulations. mike
Janicholson
02-07-2007 07:42:44
The feeling is powerful and Hs are sooooo sweeeee t. JimN
Allan In NE
02-07-2007 07:21:23
Oh Yeah, that's the way it works.
I get totally sick of every one I do..... .....Until they are done, then ya couldn't get 'em away from me at gunpoint.
Allan
