Farmall SA clutch sleeve I think!!!
Russell S.
02-07-2007 17:01:57
Can anyone tell me what this sounds like? I split the tractor thinking that I would just put a new clutch, bearing and pressure plate and be done in a weekend. well when I split her I new this wouldn't be happening. The clutch plate was all but gone, the pressure plate was badly beaten and the bearing... well what bearing. The clutch sleeve and the tube had been broken for sometime and had came out of the pressed fit.The only thing holding the sleeve was the fork. My question is. How do I get the new tube back in the hole around the shaft?
gene bender
02-07-2007 17:42:58
 Re: Farmall SA clutch sleeve I think!!! in reply to Russell S., 02-07-2007 17:01:57
It is a press fit you need to be careful because if you damage the outer end the throw-out bearing will get hung up as it has to slide free back and forth on the sleeve clear out to the end next to the pressure plate.
