Weights for front of Farmall M
Mel Stout
02-08-2007 19:18:54
I have a three point hitch on my M and a couple of attachments. Though my ground is flat, I can feel the need and want to fabricate front end weights. Anyone done this? Any pictures? Thanks in advance.
Hayfarmer
02-09-2007 07:05:37
 Re: Weights for front of Farmall M in reply to Mel Stout, 02-08-2007 19:18:54
When I got my SMTA it had the sort of triangular shaped brackets bolted on both sides to hook up a front mount cultivator. The guy I got it from had an old cultivator he gave me to haul off. I used the center hookup part from the cultivator to make a shelf to put weights on so the hook easily to the brackets and are easy to remove.
Redrider
02-08-2007 19:45:25
There two ways you can go. You can use the standard front wheel weights that are @ 50# each. You can mount them on the outside as well as on the inside. Friend of mine has two on the inside of each front wheel and you can double them up on the outside if needed. For my tractors (F400 & F300) I have built a bracket to hand 90# IH suit case weights on the front. I like that the best as it is easy to add and remove them.
RR
