Order Farmall Cub Parts Online
cold blooded Cub
dave guest
02-08-2007 20:43:18
1947 Cub well worn, thin oil, hot 12volt. Hard to start below 30 degrees. Any tips on starting. Awful cold for rebuild. Started today 15 degrees but almost killed batt. Thanks
glennster
02-09-2007 10:46:11
 Re: cold blooded Cub in reply to dave guest, 02-08-2007 20:43:18
my cub is a little testy when it gets cold too. and its real easy to flood that rascal. if you have a heat gun....or grab yer wifes hair dryer, blow the hot air on the carb to warm it up. dont cook it, just get her warm, then give it a quick shot of ether in the air cleaner, the warm carb helps the fuel vaporize better.
gene bender
02-09-2007 05:21:51
12v will start a CUB when its 30 below. #1 you must have bad starter,cables,sparkplugs,connections out of time or something else simple as a 60 cu engine is not that hard for a starter to turn the engine over on 12v. You mite not even have any compression because of bad valves i would first check compression then go from there. Take all the plugs out before running a compression test. We dont care what it reads just are all 4cycls fairly equal then we can progress from there.
old
02-08-2007 21:27:12
Add a heater to the cooling system, that way its warm when it starts up. Or you may have a carb problem. Since the carb most likely doesn't have an adjustable main jet its probably running on the lean side which will make them hard to start also
dave guest
02-09-2007 18:01:45
 Re: cold blooded Cub in reply to old, 02-08-2007 21:27:12
Thanks guys for tips.
