Farmall A plow questions
Chad from Michi
02-09-2007 06:00:57
Hello I just bought a farmall A and I am looking to see some pictures of a land plow hooked up.
This is not the one at least it looks like it doesn't use the draw bar flipped around.
The plow comes straight out to a point and has a few holes in the end that goes up under the tractor. It has all the mounting hardware and hand lift for the back. The hand lift linkages are all hard mounted this one doesn't use a chain to lift up the rear of the plow.
Does anyone have any pictures or any info that I can use to see if its all there or I have to go back after the snow melts and look for parts?
Please help
Chad
Brad in TX
02-09-2007 14:43:19
 Re: Farmall A plow questions in reply to Chad from Michigan, 02-09-2007 06:00:57
Chad, I've got several old plow parts manuals and they've got a number of the old direct connect type plows for the Farmall A's. If you can tell me the type of plow it is or a part number from the main beam, I'll bet we can figure out what type plow you have and get you some information on it. Also a picture would be very helpful as well. I'd be glad to scan the parts pages and email them to you. If I don't have the parts information on it, I'll bet gene bender does.
El Toro
02-09-2007 11:23:31
third party image
Here's an A with the plow attached. Hal
gene bender
02-09-2007 06:43:44
I can make a copy of the parts info for postage and handling.
