F 12 Timing
Roger 2021
02-09-2007 08:06:21
I had to change out the mag.I went to the service manual and set the timing where they recomended it. Next I tried to hand crank it, not even a sputter heres my question. I bring the #1 piston on compression up to TDC when I hear the mag snap the piston is down the cyl somewhere between a 1/4 inch 1/2 inch past TDC is this corect. Im a little leary of messing with the timing to much as I dont like broken arms.I would try to pull start it except I live in downtown Phoenix. The trator has steel wheels the ppd would just love that, they have no sence of humor. Thanks for any help
Dave Allgire
02-09-2007 17:57:17
 Re: F 12 Timing in reply to Roger 2021, 02-09-2007 08:06:21
I'm going to quote directly from an original owners manual for F-12 magneto timing. "Crank engine slowly until impulse trips. The D.C. No. 1 mark on flywheel should be in line with, or not more than 8 degrees below (25/32" on flywheel rim) and never above the timing mark on flywheel housing when the impulse coupling trips." That said I have cranked the engine until the mag "trips" and looked for the D.C. mark on the flywheel. If it wasn't in the proper position, I would change the setting on the "fine tuning plate" by removing the two screws and rotating the plate in the proper direction. Be careful as these two bolts have to line up exactly with their respective holes or you will only be able to get one of them to start. Put it together, crank it slowly until you get the mag to trip at D.C. #1 and see where the mark on the flywheel is. Remember in which direction you have made your adjustments so you can correct them if you have moved in the wrong direction.
gene bender
02-09-2007 13:23:59
When it snaps the piston could be down a little. Your spark and advance lever should cover that move the lever to retard spark then check again.
