Behlen Power Steering Pump used for live hydraulic
gots-to-go
02-09-2007 14:32:58
Can a Behlen power steering pump be used to install live hydraulics on a Farmall H ?
If so would it provide enough oil pressure per minute to handle power steering and a front end loader, or a three point hitch combo?
A picture of a pump like the one that I am talking about is attached.
I know that it will handle power steering alright, but can it handel other things hooked up to it as well.
Thank You Very Much
gots-to-go
RustyFarmall
02-10-2007 05:20:06
 Re: Behlen Power Steering Pump used for live hydra in reply to gots-to-go, 02-09-2007 14:32:58
That picture is mine. I posted the picture when asking the same question, and, in a nut shell, was told that the power steering pump does not have the capacity for anything more than power steering.
Wardner
02-09-2007 21:46:25
I have a pump like that except mine appears to be longer; perhaps by an inch. Like yours, it has the SAE #2 flanges on both ends. I would also say my ports are larger. It could probably be run with with a priority valve in order to handle PS and remote hydraulics. I don't think your pump is up to the task. I found my pump on eBay but have not installed it on a tractor yet.
JayWalt
02-09-2007 19:37:59
That pump is probably 3-5gpm if it is solely for power steering. Most likely it is a low pressure pump, so using it on anything but the power steering is unliklely. You could probably get by with running a 3 point hitch if you dont mind it being ridiculously slow. It would be ok for adjusting the height. Using it for a FEL is out of the question, you would go insane waiting for it to do anything, heh.
Curious as to how that pump mounts. I dont know anything about thise power steering systems, but its location looks like where my distributor is on my 300u. What tractor is that on?
JayWalt
02-09-2007 19:39:38
 Re: Behlen Power Steering Pump used for live hydra in reply to JayWalt, 02-09-2007 19:37:59
n/m, I see the tractor model above the picture, DOH!!
Nebraska Kirk
02-09-2007 17:25:06
No, the pump will not provide enough flow to be used for anything other than what it was designed for.
Steven@AZ
02-09-2007 15:30:50
Given the size of the hoses, I'm going to say no it won't provide enough GPM to run a loader.
TxAllisMan
02-09-2007 20:44:49
 Re: Behlen Power Steering Pump used for live hydra in reply to Steven@AZ, 02-09-2007 15:30:50
That looks like the exact pump on my fathers International 404 and it is used for the three point.
