574 Gas Question
ptrotter
02-09-2007 20:20:30
I am trying to determine if it possible to drop the pan on a gas 574 (c-200 engine) without removing the engine from the tractor. The tractor does not seem to have a separate frame and the oil pan is integral to the frame. There are bolts that connect the rear of the tractor to the rear of the pan and bolts that connect the front end to the front of the pan. I am afraid if I remove these bolts, that the tractor will collapse on itself. The loader frame may keep it together, but I am not sure. Has anybody done this?
Fromjb2
02-11-2007 10:55:45
 Re: 574 Gas Question in reply to ptrotter, 02-09-2007 20:20:30
Ptrotter, not familiar with the gas version but I know there is a procedure for the Diesel D239 engine to loosen some bolts and remove some others and then oil pan will come off.
Be CAREFUL be sure to put blocking under bell housing.
Jimb
