Wheel/Rim Question
Clarkbug
02-10-2007 06:09:52
Hey everyone.
I have a general question that maybe everyone can help me out with.
In my ongoing search for rear tires, I have found a set of 15.5-38 firestones, mounted on "double bevel" rims. I have a '49 M, and I have no idea what kind of rims are technically on it.
So, two questions.
1. What kind of rims are supposed to be on an M?
2. Will these other rims fit? Or should I just forget the whole idea.
Thanks in advance.
~Bug
Don L C
02-10-2007 10:35:56
 Re: Wheel/Rim Question in reply to Clarkbug, 02-10-2007 06:09:52
....don't know about fit,but 15.5 tires will stand out as far as looks...the larger tire will take more HP.to turn.. .....If you have a working tractor, I say they are to big....
Clarkbug
02-10-2007 08:23:22
Thanks for the replies.
I see after some searching (Yeah, I should have done that first) that apparently the wheel centers are different from the Drop Center (or Deep Well) type rim to the double bevel type.
I could still buy the tires and rims, dismount the tires and put them on the rims I have now, then sell the rims to someone else, but I honestly dont know if its worth the hassle... The tires are only about 50%, and for what I would pay in the mounting/dismounting, I might just be better off buying a new set of rubber and paying to mount them once.
Thanks for the input everyone!
~Bug
Wardner
02-10-2007 09:49:04
 Re: Wheel/Rim Question in reply to Clarkbug, 02-10-2007 08:23:22
Your other option is to buy a pair of eight spoke wheels from a 400, 450, 504, 560, and maybe others like 460, etc. You need to make sure that the donor tractor has the same size axle diameter.
Clarkbug
02-10-2007 12:50:40
 Re: Wheel/Rim Question in reply to Wardner, 02-10-2007 09:49:04
Thanks for the input guys.
I had thought about buying another set of centers, but I really would then rather just spend that money on a new set of rubber rather than a used set.
As far as the tire size is concerned, it has 15.5x38" tires on it right now, on the stock rims (which I think are 11" or 12"). The engine was rebuilt about 500 hours ago with the oversized pistons and sleeves to make it equivalent to a Super M. The previous owner never had a problem with it turing the bigger rubber, but I havent had a chance to see what it will do.
But I guess I'm a little worried about putting that size tire on the stock rim, so I dont mind moving down a size to a 14.9 or a 13.6 if the opportunity presents itself.
Thanks again for the replies.
~Bug
JakeF
02-11-2007 04:54:37
 Re: Wheel/Rim Question in reply to Clarkbug, 02-10-2007 12:50:40
You'll actually loose power with the 14.9-38 as they are taller than the 15.5-38's The 15.5's are a low profile and actually a little smaller contact patch than the 14.9's
Ole Sow 53
02-10-2007 08:15:04
The double bevel rims are for 400, 450, 460, and 560 Farmalls. The rims for a M are drop center.
Will Sick
02-10-2007 07:00:52
The double bevel rims would be right for a 49 M. 15.5 tires are bigger than the 13.6 that an M should have but will be okay.15.5 will speed up the tractor and cut the power a little but it depends on what you want to use the tractor for.
