finish mower
Mark Johnson
02-10-2007 08:10:58
I have a SC with a fast hitch and am lookin at getting a finish mower to mow about 1 1/2 acres of my yard.The mower that i'm lookin at has a weight of 700lbs.Anyone that uses a setup like this how did you adap to the cat 1 setup on mower? Thanks
farmallhal
02-10-2007 11:21:19
 Re: finish mower in reply to Mark Johnson, 02-10-2007 08:10:58
Mark, Have you thought about finding a 3 point hitch finish mower and then having a couple fast hitch prongs attached to the mower as in a fast hitch finish mower? I think provisions could be fabricated and installed on a finish mower which would make it quite useable while keeping the area around the PTO shaft free and clear. Actually, I saw a fast hitch finish mower for sale a few months ago on Ebay somewhere in Kansas. It appeared quite nice even if it was painted blue. Hope this helps as the fast hitch prongs can be found in salvage yards, Hal.
El Toro
02-10-2007 09:33:48
There's a man about 5 miles from me that uses a Super C for mowing and he has 2 acres or more of lawn to mow. He uses a finish finish mower on it
not sure how he has it mounted to the tractor. It's a big stone rancher and he doesn't one tree or scrub planted. Looks a little odd. Hal
Chris from Wa
02-10-2007 08:54:02
Mark, Tony Carbaugh has a one piece adapter that is almost identical to the original adapter offered as an option by IH. It is the "Farmall C Cat 1" adapter. Cost is $210. Even though Tony Carbaugh is located in Oregon, the adapter is shipped out of Missouri.
504-1
02-10-2007 08:33:19
Mark, I use a 3 point adapter on the fast hitch. Look for an adapter that is higher than the FH arms,implements won`t lift as high which can be a pain. Some adapters do not allow for the PTO shaft either.
