H engine rebuild--timing.
Tom Windsor
02-10-2007 19:37:25
Just a little update on my engine rebuild
1. The block was cooked out and cleaned.
2. New sleeves
3. Crank polished and new mains.
4. Pistons and new rod bearings installed.
5. Cam polished and new cam bearings.
6. Head refurbished and ready to install.
So, I am sitting here looking at a "New" short block trying to figure out how to time the crank, cam and magneto (distributor) drive. I am not sure how to properly time this thing..anyone know how to do this with ABC instructions? and, with the remainder of the buildup...are there any special precautions that I should be watching for from the school of hard knocks?
TW
El Toro
02-11-2007 07:49:11
 Re: H engine rebuild--timing. in reply to Tom Windsor, 02-10-2007 19:37:25
You should've taken a few notes during the teardown along with a few pictures of how the timing gear, crankshaft gear and magneto gear were meshed. The same on the connecting rods on
being installed in the correct direction and main caps during installation. Hal
Janicholson
02-10-2007 21:20:02
1}Put the crank at TDC #1 piston (Top Dead Center, closest to cam drive end.
2}With the cam gear off of the cam, apply engine assembly lube on the cam journals and cam bearings in the block, as well as the lobes of the cam.
3}Carefully place the cam into the block guiding it through the bearings with care, do not rest it on or nick the journals with the lobes or bearing journal edges. As it is inserted, keep alignment with the journals upper most in mind.
4} When it is all the way in, it will turn freely. At that point look at the gear.
5} There will be marks on the gear teeth matching marks on the drive gear on the crank. (there will be two marked teeth on the cam gear, and one marked tooth on the crank gear.
6} With the gear held in a position to mesh with the teeth on the crank gear (the two marks straddle the single mark), turn the cam so that its keyway/key is aligned with the gear's keyway.
7} Assemble them with the bolt, and torque it(I would use red locktite on the threads). The cam is now in time with the crank. Put assembly lube on the cam gear prep it for action.
8} Use assembly lube on the lifters (sides and flat ends, and put them in.
The distributor drive (or hopefully the hydraulic pump)will also have marks on its gear. Align these with the marks on the back side of the cam gear (visible in that hole), and install the drive/pump.
9} put on the oil pump (pack the gears with assembly lube).
10} Install the cylinder head as per the book, being sure to tighten the head nuts in five steps of about one fifth of the torque each, starting in the center studs, and progerssing to both ends in a repeated pattern for each torque setting.
11} Put in the pushrods and rocker arms Liberal use of lube on tips and butts of valves. Torque in steps to assure even tightening.
12}Put on a new oil filter, and fill the filter housing with oil while holding it down against the gasket, and tighten it. Put a pump type oil can in the oil pressure gauge hole using a small piece of rubber hose as a seal, and pump new engine oil into the gallery until it starts comming out the rocker arm. This assures oil pressure at start.
13} Adjust the valves cold (.020) following the book procedure.
14) Put on the pan and valve cover. torque these bolts till the gasket just starts to bulge a bit. I put a thin film of #2 permatex on the sheet metal side of these, and on the surface exposed to the oil of the engine to limit weaping through sometimes porous cork.
15} Install the distributor (one of two possible places) so the rotor points to #1 plug in the cap.
Install the engine rear seal components (if not done), then the rear engine plate, flywheel and clutch (with three bolts installed to keep it compressed).
16} install the front cover with new seal (assembly lubed up at the seal) then the pulley, being careful with the keyway. ( I believe a thin skiff of silver antisieze is a good assist in putting on the pulley, they come off so hard.
17} Then put engine in the frame, aligning the clutch splines (remember to lube the pilot bearing).
18} Attach governor components and intake/exhaust system (be careful to align the governor to throttle link at the carb carefully).
19} Put front accessories on including radiator and hoses. Attach wiring, and gauges.
20} Put in oil, fuel, and coolant.
Enjoy!!! (remember to retorque the head after it is well warmed up the first time) JimN
riverbend
02-10-2007 20:32:16
Pardon the question, but are you rebuilding this motor without a manual ?
Tom Windsor
02-11-2007 09:13:48
 Re: H engine rebuild--timing. in reply to riverbend, 02-10-2007 20:32:16
No. However, I do not understand everything I read.
TW
riverbend
02-11-2007 18:28:46
 Re: H engine rebuild--timing. in reply to Tom Windsor, 02-11-2007 09:13:48
Ah, good.
When you torque down the head keep going around in the spiral pattern until every head bolt holds 65 lb. ft. of torque. If you only do it once, the center bolts will be too loose.
If you have not done so, check that the cam lobes are all within 0.020" of 0.202" lift for a standard H). If not, the cam and lifters should be reground. Going to 0.240" lift makes a nice increase in power.
Also remember to put clean oil in the air cleaner.
Before you start the motor, leave the plugs out and spin it over with the starter until the oil pressure starts to come up. Listen for any funny noises.
To run in the engine, 1) run it about 1600 rpm for 15 minutes at no load. 2)run it a ~1780 rpm for 15 minutes at 1/2 load (I drove mine up and down the road in 4th gear) 3)run it at ~1750 rpm for 15 minutes at 3/4 load (mowed corn stalks). Instructions say 2 hours would be better.
