engine wont shut off after setting low idle
Emmy
02-10-2007 21:18:35
Adjusted the fuel injection pump High and low idle acording to my I&T shop manual today and when I pull the throttle completley down the engine stays running, drops to about 400 RPM. It is a 79 1086 with a American Bosch pump. Can anyone tell me the step that I am missing. The I&T manual doesn't mention anything about fuel shut-off for the pump.
Thanks
Hugh MacKay
02-11-2007 08:26:06
 Re: engine wont shut off after setting low idle in reply to Emmy, 02-10-2007 21:18:35
Emmy: I expect you have some wear at each pivot pin in the linkage. Do as Erik says or even just push the right direction on lever at pump. You could spend a $100. to make all those pivot point tight as new. You can also just simply shut her down from 800 rpm, from that point the linkage probably has enough momentum to shut pump down. Why are you idling that big engine at 400 rpm anyhow? Once you get below 600 to 800 shut her down, that low idling will take years off life of your engine.
Erik in WI
02-11-2007 08:03:26
Take the throttle lever off of the pump and try to shut it off with your hand (at the pump.) IF it shuts off, you may need to adjust the linkage out more to get it to do it with the trottle.
Erik
