W9 intake manifold
rhm
02-11-2007 04:46:06
I was out looking for a parts tractor for my W9 project and found one with a two piece intake/exhaust manifold. The name Johnson machine is cast into the intake. It looks to be in good shape. Does anyone know anything about this manifold?
Red48m
02-11-2007 18:09:34
 Re: W9 intake manifold in reply to rhm, 02-11-2007 04:46:06
Well if thats the case, its perfect for you. No exhaust heating up the intake, means colder air going in=more power!
Red48m
02-11-2007 14:25:04
The manifold is for LP use. It will work good unless you are running the tractor in cold weather.
rhm
02-11-2007 16:00:38
 Re: W9 intake manifold in reply to Red48m, 02-11-2007 14:25:04
Thanks Red, I plan on using the W9 for pulling so cold weather is not a problem. This type of intake is a first for me so I had to ask.
