Is it a C or Super C?
Joe Kimbriel
02-12-2007 18:37:35
I finally got a chance to start identifying the tractors we bought and this one sounds funny. The serial number is FC 2702 but the hood says Super C. What is it? The serial numbers at left indicate that it is a 1948 C. How many C’s did they make? It must have been a bunch.
City-Boy McCoy
02-13-2007 03:56:17
 Re: Is it a C or Super C? in reply to Joe Kimbriel, 02-12-2007 18:37:35
Another quick way to check, which is pretty reliable: Look at the location of the crank hole in the bottom of the grill. If it is basically even with the bottom bars in the grill, it is a C. If it is noticeably lower than the bottom bars, it is a Super C. mike
Paul Shuler
02-12-2007 19:02:58
Hope this helps a little. The Super has a taller grill and curve brake and clutch pedals. And a water pump. Some supers also will have a fast hitch in the rear. Both good machines.
Dave 2N
02-13-2007 09:06:04
 Re: Is it a C or Super C? in reply to Paul Shuler, 02-12-2007 19:02:58
"Thumbs Up!" Paul. Nothing prettier than pretty Farmalls. Good job.
Joe Kimbriel
02-13-2007 07:20:21
What a couple of nice looking tractors. I hope ours turn out that good. We are finding out that it gets very expensive to get everything back to original, but it sure is fun.
Joe Kimbriel
02-12-2007 19:12:43
Water Pump ? Whats that? All the tractors that I have identified as what I thought was a Super C don't have water pumps. The fan just hangs out there.
Paul Shuler
02-12-2007 19:30:05
 Re: Is it a C or Super C? in reply to Joe Kimbriel, 02-12-2007 19:12:43
The water pump will run off a belt coming from the fan on the carb side of the front of the engine.
Joe Kimbriel
02-13-2007 07:14:30
 Re: Is it a C or Super C? in reply to Paul Shuler, 02-12-2007 19:30:05
Wow, Did all Super C's have water pumps. What about just C? It sounds like we bought a bunch of hybread's (sp). I'm headed back out there with all of this info to see really what I got.
Thanks,
used to be ny bill
02-12-2007 18:50:59
super c serial #s started with 100001, so all super c's have 6 digit numbers. yours would seem to be a 1948 c, as you said.
gene bender
02-12-2007 18:49:12
Acording to the serial# it is an early C. The SC started with 100,ooo and up
Joe Kimbriel
02-12-2007 19:06:47
 Re: Is it a C or Super C? in reply to gene bender, 02-12-2007 18:49:12
Thanks, must have gotten a upgraded hood somewhere along the line. Now that I look at it the hood's paint is too good for this tractor. Hmmm going to have to look at the rest of them to see where the hood fits.
Nat 2
02-13-2007 04:58:11
 Re: Is it a C or Super C? in reply to Joe Kimbriel, 02-12-2007 19:06:47
No, someone put Super C decals on it when it was repainted.
