Delco distributor
Oregonfarmer
02-12-2007 20:03:42
I have Delco dist unit for my H that now has battery ignition with IHC dist. Is there any advantage to using the Delco unit over the IHC?
Thanks
Buzzman72
02-13-2007 09:21:38
 Re: Delco distributor in reply to Oregonfarmer, 02-12-2007 20:03:42
Not certain about it, but if you're converting an H to live hydraulics, I believe the Delco will have a little more clearance at the oil filter housing than the IH distributor.
glennster
02-13-2007 06:59:13
i have a 42 m that was converted from a mag to a delco distributor. the i-h distrubutor lays horizontal on the motor, my delco sits vertical. never had a problem with it. be sure it has grease in the housing.
Janicholson
02-13-2007 06:53:29
If (and only if) the Delco has good bushings and little wear, and the original is toast. Use a dial indicator on the rotor shaft to check runout. if more than .001, it needs new bushings. JimN
randy hall
02-12-2007 20:10:11
no
