Order Farmall Cub Parts Online
Cub 22 or L-22- Mower
thebigron
02-13-2007 04:58:26
Can"t figure out if I have the L-22 or 22 cycle mower, but have finally discovered that on the rear pulley there is evidence of a blue paint. Were these mowers painted from the factory blue as it appears and if so what paint would closely replicate it? Thanks for any help.
thebigron
02-13-2007 19:04:44
 Re: Cub 22 or L-22- Mower in reply to thebigron, 02-13-2007 04:58:26
Thank you all for your responses. This is just the information I was needing; as soon as I get a bar will be able to put this mower to work.
Jim Becker
02-13-2007 07:19:02
There are substantial differences between the Cub-22 and L-22 mowers. Look at the pictures on the TM Tractor web site.
K-Mo
02-13-2007 05:17:56
The 22 mower is for the Farmall Cub and the L-22 is for the International Lo-Boy. Same mower. The difference is in the mounting hardware. The 222 is for the 154, 184 & 185 Lo-Boy. There is also a 105 mower which has a balanced head.
Vansickle Paint has the International Blue.
K-Mo
El Toro
02-13-2007 05:32:27
 Re: Cub 22 or L-22- Mower in reply to K-Mo, 02-13-2007 05:17:56
Here's PPG's paint numbers, you should be able to find a blue that's close. Hal
PS: I like their Omni.
www.worldpath.net/~thompson/misc/PPG%20Tractor%20Colors.htm
