super c year
cdf
02-13-2007 09:50:10
found date code 5-10-x on top cover i was told this was a 1952 i also found the number 354898 r1 on block does this still seem to be a 1952 and what does r1 mean
cdf
02-14-2007 08:43:21
 Re: super c year in reply to cdf, 02-13-2007 09:50:10
all i am trying to find out is the year of my super c because the serial number tag is missing sorry for the confusion thank you for the engine info
Hugh MacKay
02-14-2007 09:03:15
 Re: super c year in reply to cdf, 02-14-2007 08:43:21
cdf: That being the case, the only choice you have is casting date codes.
cdf
02-14-2007 04:40:46
this engine is in a super c just trying to find out if it is in fact a super c
Hugh MacKay
02-14-2007 07:49:15
 Re: super c year in reply to cdf, 02-14-2007 04:40:46
cdf: I'm missing something here, if the engine is in a Super C, then why would you be trying to find out if it is in fact a Super C.
Is it the engine your and your questioning whether it belongs in the Super C. Well the part number 354898 R1 is indeed a Super C engine block. It is also a Super A engine block after serial number 310300. The only difference in the two applications will be the Super C has 3-1/8" bore sleeves and matching pistons, while the Super A will have thicker wall 3" bore sleeves and matching pistons. If that is what your trying to figure out, shut down the computer and grab the wrenches, as that is the only way your going to find out for certain. Take the head off.
Hugh MacKay
02-13-2007 14:39:30
cdf: That engine block part number 354898 R1 came from either a Super A or Super C. That block part number was never cast until mid 1951, and was used on all Super A after serial 310300 and all Super C. The same part number in R3 was used in 100 and 200.
You'll have to find the block date code to be sure which of 51, 52, 53 or 54 the block was cast. That engine may well be in a C now, but it did not come in a C.
Nat 2
02-13-2007 12:21:52
5-10-X is the day the part was cast. May 10, 1952.
If most of the major castings on the tractor have a similar date code ending in "X" then it's a safe bet that the tractor was built in 1952.
However, if the major castings have different date codes, you have a "mutt" built from parts tractors.
The number ending in R1 is the part number for the part. That tells you nothing about the date of manufacture.
El Toro
02-13-2007 11:55:29
That may be the block's casting number. The Super C had disc brakes and the brake pedals were curved. Some had the fasthitch too. Hal
El Toro
02-13-2007 11:21:18
I'm not sure about the serial number being from a Super C. It may have came off a Super A. There was only 98000 built so the serial numbers couldn't be that high. It's still the same engine if they used the C123 engine, Hal
Red Dave
02-13-2007 11:13:48
354898 r1 is an IH part number. R1 is revision #1
Look on the side of the tool box under the seat for an aluminum plate about 3 inches X 4 inches. It should have the serial number stamped on it. Then click on the "Serial Numbers" link at the left and look up the year.
If it is a 100,000 or higher, it is a Super C, if it is 5 digits or less, it is a Straight C.
