424 needs a facelift
Gary in Mozarks
02-13-2007 09:57:34
third party image
Here's the 424 we put together from two junkers. Still needs a facelift The nose cap is a 460 with a section removed from the middle to make it fit.
Joel Cassell
02-13-2007 17:47:31
 Re: 424 needs a facelift in reply to Gary in Mozarks , 02-13-2007 09:57:34
Hi Gary,
Did you get the shifting issue you were having fixed ok?
Thanks,
Joel
Gary in Mozarks
02-13-2007 18:50:26
 Re: 424 needs a facelift in reply to Joel Cassell, 02-13-2007 17:47:31
Joel, Yep, pretty much. The shift lever came out of the top cover just like they said it would, I got it unstuck out of reverse, and put all the bolts back I removed trying to get the entire top cover cover off. I still have to weld up the end of the shifter. But I already repaired the one on our 460 so I am familar with that. So its pretty much solved. We are in the middle of another ice/snow storm, so I will wait till it warms up a little next week to finish it up G
