change over from gas to diesel
ole farmall
02-14-2007 17:12:55
I dont know if this question is stupid or not..but i was just wondering if you could convert a gas motor on a M to a diesel running motor...i know you would probly have to use a diff head..and put glow plugs in..also all the fuel pump stuff...i think it would be cool it some one made a M diesel that was a gas...but didint make the start up on gas..so it would be a true diesel..this could be made with some custom parts right??
Jason Simmerman
02-14-2007 20:30:51
 Re: change over from gas to diesel in reply to ole farmall, 02-14-2007 17:12:55
I honestly think it would be easier if you wanted a direct start diesel to convert the existing gas/diesel motor to a direct start. You would have to add glow plugs and figure out what to do about the distributor ect ect, but that would be by far the easier way to go.
RayP(MI)
02-14-2007 18:26:23
Ask anyone who owned a Oldsmobile 5.7 diesel engine. They tried to make a diesel out of a gas design. Many,many failures. Suprisingly if they didn't fail, they were pretty dependable!
MN Scott
02-14-2007 18:22:38
IH did it with the D282 6 cylinder diesel. The crankshaft in a 282 diesel is the same as in a C263 gas. Thats why a D282 has head gasket problems, the gas block does not have enough head bolts per cylinder.
Owen Aaland
02-15-2007 13:03:38
 Re: change over from gas to diesel in reply to MN Scott, 02-14-2007 18:22:38
Although the crankshafts are dimensionly the same you need to be careful when interchanging them. There are five different shafts used. Early diesel shafts are not regrindable. A couple of the gas shafts will break if used in a diesel. Any shaft can be used in a gas engine.
Bob M
02-14-2007 18:03:50
Would indeed be cool. But it's not unlikely it could be made to work. The M gasoline block and crank, while robust, are simply inadequate for the higher stresses of diesel operation.
Just compare a few spec's for M gas and M diesel (MD) engine crankshafts:
Number of main bearings: gas = 3; diesel = 5
Main bearing diameter: gas = 2.80"; diesel = 3.75"
Crankpin diameter: gas = 2.55"; diesel = 3.25"
As you can see the diesel M engine is built MUCH heavier...
Incidentally direct electric start diesel M's DO exist in the form of the the British built BMD. But the BMD diesel is also much more heavily constructed than it's gasoline counterparts.
HAS
02-14-2007 19:16:10
 Re: change over from gas to diesel in reply to Bob M, 02-14-2007 18:03:50
Not to mention the compression ratio difference.
Steven@AZ
02-14-2007 18:00:32
Would be easier to convert a diesel to a gas.
The gas engine will never handle the stresses and pressures of compression ignition...
If you want a direct-start diesel in your M retro-fit it with a 4bt Cummins or find one of those Sheppard conversions... or even the 2-71 GM diesel was put in some of them!
old
02-14-2007 17:56:46
I agree with Gary, been tried and when done it would blow the bottom right out of them in a heart beat
Gary in Mozarks
02-14-2007 17:40:04
The best answer I can give is to compare it to GM. GM tried to made a diesel engine out of a gas (350) and spent millions on the project before producing one of the worst engines they ever built. Just to many things have to be beefed up to make it work. Even though they made it work, the engines failed so fast that most of those cars were reengined within a few years. Better to use an engine designed from the ground up to handle the compression (at least 4 times greater)
Allan In NE
02-15-2007 02:22:07
 Re: change over from gas to diesel in reply to Gary in Mozarks , 02-14-2007 17:40:04
The only thing wrong with that old 350N was the nut behind the wheel.
I always am a bit amused by the old wives’ tale about the Olds 350 diesel being "converted" from its gasoline counterpart. That's just plain bunk; nothing was "converted". The 350N is/was a totally different engine.
The two engines share the same general overall appearance. I.E. They "look" the same in general configuration, but that's just about as far as it goes.
Parts that can be interchanged from the gas engine to the diesel are as follows:
1. Oil pump body and the oil pump drive shaft. 2. The rod bearing 'inserts' and rod fastening bolts only. 3. Push rods and rockers out of a gasoline engine will indeed “work” in a diesel.
Everything else is diesel specific down to and including the wing nuts on the air cleaner.
Allan
Gary in Mozarks
02-15-2007 06:05:17
 Re: change over from gas to diesel in reply to Allan In NE, 02-15-2007 02:22:07
Alan, Living in Lansing Michigan at the time, I had a friend who was an engineer on that project. I agree with you in that it was not a "converted" gas engine. But they did start out with the basic blueprint (Spacing, layout) of the gas engine,(as they had tooling for it) By the time they got done beefing up what was needed, there was very little in common with the 350 gas engine anymore, and that was my point. It's not pratical to make a diesel out of a gas engine.
Allan In NE
02-15-2007 09:08:42
 Re: change over from gas to diesel in reply to Gary in Mozarks , 02-15-2007 06:05:17
Oh Yeah,
I see where you're coming from now.
It's so darned hard to "read between the lines" on this Internet. :>)
Allan
