Looking for a rare part
Guff
02-15-2007 15:05:10
I live outside the Denver area and my local John Deere/Ford/Kubota tractor dealer says he can't find what I'm looking for. My 51 H has a PTO pump for my (farmhand?)loader. There is a coupler between the PTO and the pump, or there used to be a coupler... Does anyone know where I can find a coupler with a standard 6 spline PTO on one end and a 7/8" shaft on the other, with a keyway and set screw in the keyway? Its approx 4.5" long.
Thanks in advance,
Guff
Bob
02-15-2007 17:32:44
 Baum hydraulics in reply to Guff, 02-15-2007 15:05:10
Baum hydraulics will have what you need. If they won't sell direct to you, get the dealer to call them, or ask the Baum folks if they have a reseller set up in your area.
Wardner
02-15-2007 15:59:44
 Re: Looking for a rare part in reply to Guff, 02-15-2007 15:05:10
You will probably find what you want at the link below. If you can't find it, the site has other pages.
These people (www.hubcityinc.com) are mfgs. Copy the part # and call your local bearing house. You could also contact McMaster-Carr, MSC, or Graingers and give them the HubCity info.
IaGary
02-15-2007 15:30:15
You can make one by buying a weld on hub for a sprocket and any PTO splined coupler and welding the two together.
Might have to have a machine shop put the splined end in a lathe to get it cut straight.
Gary
gene bender
02-16-2007 05:20:13
 Re: Looking for a rare part in reply to IaGary, 02-15-2007 15:30:15
You forgot to tell him he needs two sprockets the same and a piece of double roller chain for the coupling.
Iagary
02-16-2007 13:00:53
 Re: Looking for a rare part in reply to gene bender, 02-16-2007 05:20:13
Gene to drive a pump like that he could weld the two hubs together.
georgeky
02-15-2007 15:14:10
Try TSC they usually have a few couplers for spray pumps. I am not sure if they are heavy enough to handle hydraulic pump.
