MTA hydralic system
Bill Brown
02-15-2007 15:48:59
recently purchasea a MTA and in place of the hyd. lever there is a short lever with three slots which i suppose will operate the system. My question is, will this be able to operate a two way cylinder??? any info will be much appreciated
Armand Tatro
02-17-2007 14:42:31
 Re: MTA hydralic system in reply to Bill Brown, 02-15-2007 15:48:59
save that control even if you don't use it. I have never seen 1 like it For more information refer to I & T manual. Armand
georgeky
02-16-2007 08:36:55
I have looked through my books and they do show the control and a schematic of it but, none of them say for sure whether it is double acting or not. Since I have never had one I just do not know for sure. Keep reading someone here does know.
georgeky
02-16-2007 08:20:22
Bill I forgot part of your question I believe the select o lift is double acting. If not some one else will correct me.
georgeky
02-16-2007 07:59:55
Bill that is an original selective lift control for the Super MTA. It is to operate more than one remote cylinder independently of one another.
Hayfarmer
02-16-2007 07:00:57
If it has live hydraulic pump it is easy to put a valve on to operate double acting cylinder wither the original "Christmas tree" valve or any open center hydraulic valve. I had the Christmas tree valve on my SMTA but wanted 2 remotes so went to a Prince valve.
Ksfarmmer
02-16-2007 06:32:05
First time I have ever seen anything like that if that indeed is what you have. I would think if what you have doesn't work, it would be rather simple to return to the orginal assuming you could find the required parts in a boneyard. Been a long term since I drove our old MTA, but I think the hydraulic controls may be similar to the M or at least adaptable. If old parts aren't available there surely must be some new hydraulic valves/controls available that you could certainly make work. I'm sure others will correct me if I am wrong.
Wardner
02-15-2007 16:12:15
third party image
It sounds like you have a Select-O-lift attachment. It is a IH hydraulic splitter for lifting one or both sides of a cultivator. I believe they are single acting so you will not be able to run a double acting cylinder.
If the pic doesn't show, goto item 250083719368 at eBay for the pic.
