Missing distributor cap clip.
Tom windsor
02-16-2007 18:10:13
Does anyone have the clip that holds distributor cap on an H distributor in their junk box? Need one.
Tom Windsor
NDS
02-17-2007 05:34:37
 Re: Missing distributor cap clip. in reply to Tom windsor, 02-16-2007 18:10:13
My IH dealer had them in stock couple of years ago.
Bill Geer
02-16-2007 20:28:06
I think I got a clip. I will look in the moring. Bill
Fancy Farm
02-16-2007 19:35:21
Had the same problem with my H went to salvage yard with a lot of old chevys and got a clip. I had to shorten the clip I found you have to heat the end of the clip red hot to bend it. you will also have to grind the edges of the clip to get the proper width on the end you bend.
Bob
02-16-2007 18:36:30
I would have a used clip, or check the dealer to see if they are still available...
Spring (clip) is 353 894.
Support (part attaching screw goes through) is 353 895.
