H Fan Shroud
Wisconsin Cowma
02-17-2007 11:08:36
I was getting my H back together. I had the radiator bolted down and steering shaft on too. Then when I got to putting the sheet metal back on her there was the fan shroud sitting there. Now the question is. Is there way to sneak it in there? Or do I have to take the radiator off again?
TDK
02-17-2007 21:23:30
 Re: H Fan Shroud in reply to Wisconsin Cowman, 02-17-2007 11:08:36
I did the very same thing this past summer, after everything was painted. I don't recommend this after painting, but you can get it back on after removing the stuff Rusty & Andrew mention. I only had two small scratches which were easily touched up. Good luck !
Andrew Z
02-17-2007 14:48:14
Yes you can sneak it around you need to remove the hood as Rusty said and losten up the supports that hold the raditior on the top one mainly, I cant recall weather or not I had to take the top hose off. I did sneak mine in on our 54 Super H, last year, it took me about 2 hours from start to finish.
Andrew
RustyFarmall
02-17-2007 12:52:34
You will need to remove the sheetmetal, but I don't think you will need to remove the radiator.
Tom Windsor
02-17-2007 12:08:54
No sneaking allowed...you are going to have to do it the hard way or not install it at all.
TW
