h trans rear
bbaro25
02-17-2007 15:00:49
i have an h farmall, i was checking fluids and when i got to the trans & rear it seems like it is full of grease not fluid. has anyone run across this and what is my best way to clean it out and could there be any damage caused by it. it does run and drive well. thanks
Haas
02-18-2007 08:12:05
 Re: h trans rear in reply to bbaro25, 02-17-2007 15:00:49
While it's common to put grease in the steering gears, I would never do that in the transmission as the situation is entirely different. The transmissions have oil channels for the oil to flow through the bearings. The gears sling the oil up into the channels and then it flows by gravity through the channels to the bearings and back down to the sump. If there is only gease in there, the bearings may not get proper lubrication and cooling. This would be especially true under heavy load. All that said, seems like the bearings in the transmissions of these old tractors last forever in spite of a lot of abuse. I overhauled a Super H transmission a few years ago and I replaced several bearings due to wear. The oil flow channels were all blocked up with sludge and I think the bearings wore due to inadequate cirulation of the oil.
bbaro25
02-18-2007 10:05:17
 Re: h trans rear in reply to Haas, 02-18-2007 08:12:05
thanks for everyones input, i guess i will try to flush everything out with kero. a few times and refill with gear oil in hopes no damage was caused as i have not put any hours on it since owning it, however who knows how long it has been like this. again thanks for the help. brian
Steven@AZ
02-17-2007 15:49:29
Old gear oil will seem like grease. I've drained it out of several older tractors... Personally, I drain and fill with diesel fuel, drive around the yard for a while, and drain.
On my F12, we had to pull the cover off and scrape the goo out...
JayWalt
02-17-2007 15:46:58
goerge is right on. about the only thing i would think about using grease in (besides the locations calling for grease), is maybe the steering box since there is alot less movement then in like a transmission.
Georgeky
02-17-2007 15:35:31
Sometimes when seals go to leaking instead of fixing them some folks fill various things including tractor rear ends with grease to slow down leaks. I dont recommend it. However I do use it in my bushhog gear boxes for the same reason.
