IH spray bomb problems
Gauger
02-18-2007 07:30:18
Anybody have complaints about the IH spray bombs??? Nozzles clogging etc. I follow the rules explicitly, ie. can upside down and spray to clear the nozzle and even soak them in lacquer thinner after use and I still wind up with problems. Not even sure it's the nozzle. I have a can of primer of which I used about a quarter and going back to it later it won't spray, tried three different nozzles. Getting ticked off, they get $6 a can for this stuff. This is not new, I've used dozens of these bombs over the years and have had issues with many of them. Is it me??!!
Don L C
02-18-2007 10:39:28
 Re: IH spray bomb problems in reply to Gauger, 02-18-2007 07:30:18
...I turn can over and spray until I don't see any paint, then i wipe nozzel with pape towel....
...A good tip for guys that like to paint with (bombs or rattle cans).....place cans in pan of hot water and heat to about 180f.....
Vern-MI
02-18-2007 07:52:52
I don't have as many problems with the spray nozzles as I do the pick up tube inside the can. The tube will plug with pigment solids at the point where it enters the bottom of the pick up tube if I don't remember to shake the can vigorously before I press the nozzle. Shaking the can causes the pigment to be be re-suspended in the paint solution and not caked in a layer in the bottom of the can. Once the pigment is evenly suspended in solution then it is alright to press the nozzle.
gauger
02-18-2007 18:07:26
 Re: IH spray bomb problems in reply to Vern-MI, 02-18-2007 07:52:52
Sounds reasonable, I'll give it a try
