M FARMALL CAMSHAFT
CHIEFEAVES
06-22-2007 13:27:03
NEED TO REPLACE CAMSHAFT ON 1939 M. SEEN ONE ON EBAY NOT SURE IF SHOULD TRY TO REPLACE WITH USED ONE OR GO AHEAD AND PURCHASE A NEW ONE. I AM PUTTING ALL NEW SLEEVES, PISTONS, RINGS, ROD AND MAIN BEARINGS, AND CLUTCH KIT.
WHAT SAY TRACTOR VET OR SOMEONE ELSE THAT HAS MECHANICAL KNOWLEDGE?
I AM NOT A MECHANIC JUST LOVE TO DRIVE OLD TRACTORS.
the tractor vet
06-22-2007 16:14:37
 Re: M FARMALL CAMSHAFT in reply to CHIEFEAVES, 06-22-2007 13:27:03
Well i did one of them after market camsand i am nbot happy with the performance of them as they come from the land of ALMOST WRIGHT . Now what i have done since is have the cams rebuilt by the one machine shop that did some of my work as they are more precice on lift and duration . And for what they were chargen me for this it was less then buying IMPORTED JUNK. Now if ya do go with a new cam the do go with new lifters or atleast have the old ones reground . And if ya can go with the 450 cam specs.
RustyFarmall
06-22-2007 13:37:26
You've already spent some pretty good money. Get the most bang for your buck by purchasing a brand new camshaft. Camshafts do wear out, and when that happens the valves will not open as far as they should and performance will suffer.
CHIEFEAVES
06-22-2007 13:47:46
 Re: M FARMALL CAMSHAFT in reply to RustyFarmall, 06-22-2007 13:37:26
YOU GOT THAT RIGHT. I GAVE A $100.00 FOR THE TRACTOR. IT HAD BEEN SITTING IN THE PASTURE FOR 20 ODD YEARS. HAVE ALREADY SPENT OVER $2000.00 AND CLIMBING BUT SURE HAVE ENJOYED TRYING TO LEARN HOW TO MECHANIC. OLD RETIRED ARMY CHIEF's HAVE TO DO SOMETHING TO KEEP THEMSELVES OCCUPIED.
THANKS RUSTY
El Toro
06-23-2007 11:23:28
 Re: M FARMALL CAMSHAFT in reply to CHIEFEAVES, 06-22-2007 13:47:46
Here's a web site for a few of the old Army vehicles we tested at APG. We did the M88 Recovery Vehicle too both gas and diesel versios.
One of best tests that I ever worked on. The M578
and the M564 Gamma Goat was both hot projects when they arrived at APG for testing. We worked a lot of overtime on these projects. Hal
http://www.usarc.army.mil88thRSC/other-units/history-museum/trucks.htm
El Toro
06-22-2007 14:12:44
Is that a retired CWO? Hal
CHIEFEAVES
06-22-2007 14:24:28
 Re: M FARMALL CAMSHAFT in reply to El Toro, 06-22-2007 14:12:44
YEP FRAID SO. CW5 TO BE EXACT. 43 YEARS 9 MONTHS. HAD A GOOD CAREER AND NOW REALLY ENJOYING BEING AT HOME WITH MAMA AND REAPING THE BENIFITS.
El Toro
06-23-2007 05:57:58
 Re: M FARMALL CAMSHAFT in reply to CHIEFEAVES, 06-22-2007 14:24:28
third party image
With new cam bearings and close tolerances on your main bearings will give you good oil pressure. Make sure you have the crankshaft measured for wear too. here's a picture of a vehicle we used for drawbar pull and cooling tests at APG. Hal
PS: The Bradley and M1A1 tank were among them too
CHIEFEAVES
06-23-2007 07:30:58
 Re: M FARMALL CAMSHAFT in reply to El Toro, 06-23-2007 05:57:58
THANKS FOR THE GUIDENACE. I AM HAVING THE CRANKSHAFT TURNED TO .30 IN THAT IT HAD ALREADY BEEN TURNED TO .20. HAL I MAY WANT TO BORROW THAT RIG TO LOAD TEST THE M WHEN I FINISH.
El Toro
06-23-2007 07:39:07
 Re: M FARMALL CAMSHAFT in reply to CHIEFEAVES, 06-23-2007 07:30:58
Would you believe they scrapped that vehicle after I retired. They had new dynamometers built, but they never controlled like the old M7 did. Hal
El Toro
06-22-2007 16:29:47
My late brother-in-law was a retired CWO4. He served in WW2, Korea and Viet Nam. I'm retired
from Aberdeen Proving Ground after 43 years and 2 of those was with the Army during the Korean War at Ft Bragg with the 82nd.
Be sure to install new cam bearings along with that new camshaft. Hal
