806 waterpump
kerm
06-23-2007 08:05:49
Just replaced the waterpump with a reman from CIH. When I tightened the mount bolts the pump drags a little bit. Can here it rubbing inside the housing. Should I file the fins or take it back? Thanks for your help... Kerm
kerm
06-23-2007 12:34:15
 Re: 806 waterpump in reply to kerm, 06-23-2007 08:05:49
Didn't come with a gasket. parts book doesn't show one.
the tractor vet
06-23-2007 16:30:21
 Re: 806 waterpump in reply to kerm, 06-23-2007 12:34:15
Then the parts man does not know his arres hole from a hole in the ground as it need a gskt. As they did not come from the factory with yucky pucky .
kerm
06-23-2007 16:51:06
 Re: 806 waterpump in reply to the tractor vet, 06-23-2007 16:30:21
the pump has a O- ring on the hub but there is no gasket for the flang.
the tractor vet
06-23-2007 20:07:35
 Re: 806 waterpump in reply to kerm, 06-23-2007 16:51:06
It's been awhile since i had to do one and i guess i am getting foggy . The last 806 water pump that i did was back 12-15 years ago and i did the rebuild myself as back then that is the way it was done . So if no gskt then they did not press the impeller on far enough or when they pressed the hub on they pushed the shaft thru the bearing and did not catch it as i have done that a couple times but caught my mistake and had to press the shaft back .
Wisconsin Cowman
06-23-2007 10:37:14
Take it back and tell them you want a differnt one.
TxFarmallFan
06-23-2007 10:05:57
I'd take it back. For the money they charge for parts, they ought to be perfect.
the tractor vet
06-23-2007 08:34:28
Did ya use the Gskt.??? if ya just used yucky pucky then it may hit . If ya did use the gskt then take it back as they did not press the impeller on correctly.
