560 diesel hydraulic problems
Gavin Ahlbrecht
06-23-2007 20:50:41
I see my son has been doing his best to help me out. Can't ask for any more than that. How do we lock the 2 pt hitch? We tried all kinds of combinations of hookups with set a and set b. If the 2 pt lever is in the up position, we can pull back on the other levers and the hitch will raise. My dad still think that something is wrong in the valve. Not sure. The tractor looks good after restoration though. We put a rock box on her, 9.5L 15 tires on the front, and 16.9-38 Firestones on the rear. Those rear tires don't make the flat top fenders look so gawdy on the back. It is a real nice match. We really made a tractor out of her. Thanks in advance for your help Bill.
Brian in MO
06-24-2007 05:47:50
 Re: 560 diesel hydraulic problems in reply to Gavin Ahlbrecht, 06-23-2007 20:50:41
Gavin I don't completely understand what is happening but all 3 hydra levers should act independent of each other. If moving something other than the lever for the fast hitch is effecting the hitch then it sounds like you must have a problem in the valves.
Gavin Ahlbrecht
06-24-2007 08:08:50
 Re: 560 diesel hydraulic problems in reply to Brian in MO, 06-24-2007 05:47:50
I think it is something in the valves as well. I just don't have time to fix the valve right now. Funny thing is that it worked before I took the hoses off from under the seat. I was wondering how I can lock the 2 pt hitch in the middle to up position so I can bale hay this afternoon. I wish I could fix the 2 pt hitch problem but I have hay down and I deploy to the desert on the first of July. I can fix it when I come back around the first of October.
