Oversize Hex Nuts
Pale Rider
06-24-2007 22:21:52
In removing parts from my F-20 and F-12 I occasionally find that I either destroy a hex nut or it is too far rusted to have any reliable wrench surface to begin with. I could of course just replace it with a modern nut but I find that the nuts used were typically, if mysteriously, oversized by one wrench size. For example a hex nut for a 3/8's bolt would require a 5/8's wrench to remove as opposed to a 9/16's wrench as one would expect for modern hex nuts. This pattern seems to run pretty true with the other size bolts as well. If this were not enough, I find that many of these old hex nuts that are in good shape seem to have been punched from some sort of rough plate steel still having some sort of milling marks running accross their surface, and once in awhile I even find one that was not drilled on center but is whimsically eccentric in it's hole location. Does anyone know of a source for what I assume would have to be old stock International hex nuts? Or failing that, a source for hex nuts that would be oversized with regard to the wrench required for their removal?
don g
07-02-2007 19:03:38
 Re: Oversize Hex Nuts in reply to Pale Rider, 06-24-2007 22:21:52
another reason the oversized bolts and nuts are used in steel erection eliminates need for flat washers so maybe that is the idea for the tractor as well
Haas
06-25-2007 18:23:26
I believe these are called "heavy hex" nuts. I think they are used most often in structural steel applications. I don't know why. However, I find them quite a bit on the IH tractors and equipment. You won't find them in most hardware stores. I think you'll have to go to a fastener supply house, or to a commercial hardware wholesale house that supplies fasteners and hardware for industrial and commercial operations.
Nat 2
06-25-2007 07:44:43
The REAL reason for the oversize nuts is so you only need one set of wrenches to remove a bolt.
RustyFarmall
06-25-2007 05:41:58
Those over-sized nuts are called heavy duty nuts. They were used because of the greater surface contact area which spreads the load out and results in a stronger connection. You should be able to find them at most farm machinery dealerships. A GOOD hardware store will also have them. I have never found them at ANY farm supply store. Another choice might be McMaster-Carr or possibly Fastenal.
Fawteen
06-25-2007 01:19:36
At work, we use a lot of 3/8 to 3/4 hardware, and can get two sizes of nuts for each, "regular" (a 9/16 nut for a 3/8 bolt) and what I assume is "heavy duty" or the next size up (5/8 for a 3/8 bolt).
In this case it's SS stuff, but I'd assume it's also available in regulart steel. We get ours from McMaster-Carr.
Chris(WA)
06-25-2007 01:15:52
There is a Heavy nut sold by hardware supply stores that is a wrench size larger than regular.
