cutter part
Basil Greenleaf
06-25-2007 09:26:19
I'm lookiing for a IH Rotary cutter part. The 5 Ft. 2 blade cutter is about 25/30 years old. I don't know the model number but most likely IH only made one model at the time. I need the big arm that is bolted to the gear box drive shaft under the mower and the 2 blades are mounted to. The blades swing freely at the end of the arm. If you have one please let me know. Thanks, Basil
glennster
06-25-2007 10:34:39
 Re: cutter part in reply to Basil Greenleaf, 06-25-2007 09:26:19
could be a model 27 rotary mower. i have a 5 ft trailing type i-h rotary, model 27. blades are still available from the dealer, dont know if the center part is.
Michael Sheik
06-25-2007 10:24:46
Are you talking about what is called a brush-hog mower.
Basil Greenleaf
06-26-2007 04:10:21
 Re: cutter part in reply to Michael Sheik, 06-25-2007 10:24:46
Same principle, only it was made by IH. Can be used to cut corn stalks, bean stubble or any thing that grows. I use mine to keep my wild hay and weeds under control. Thanks, Basil
