Re: IH 254 Hydraulic Stopped Working
Shredder
06-25-2007 17:50:46
Well, I finally got back out there. Been busy and it's been raining for a week.
There is definitely hydraulic fluid moving through the system when the engine is running. I can see it in the filter housing when I remove the cap. Also the fluid level is full.
When I move the 3ph lever the pump doesn't run. Normally when I move the lever to raise the 3ph the engine strains a little. Now nothing happens. The pump isn't pumping.
What should I check next? Could the problem be in the relief or control valve? This tractor does not have power steering and the PTO is mechanical. I can see no visible problem with the linkage but I'm not sure I would recognize a problem.
There is water in the hydraulic oil but it was there before I shredded 2 weeks ago and I had no problems. I had drained and replaced some of the water-oil and will completely change it when I fix this problem.
Any help greatly appreciated. The pasture weeds are getting tall:(
Norm
Shredder
06-26-2007 16:35:19
 Re: IH 254 Hydraulic Stopped Working in reply to Shredder, 06-25-2007 17:50:46
Correction: the pump appears to be pumping. It isn't straining the engine like it normally does when I move the 3ph lever, but when I loosen the high pressure line fluid squirts out. I don't have the experience to tell if there is the correct amount of pressure though.
So, there is fluid moving through both the high and low pressure lines, but I can't raise the shredder. Other than that everything seems to be working OK.
Can someone help me with this?
Norm
