TA linkage adjustment on a 340U
PaulW_NJ
06-25-2007 20:37:29
The TA on my 340 Utility works fine if you hold the handle all of the way back manually. However, if you just latch it in the engaged position without maintaining rearward pressure, it does not engage. I assume there is an adjustment problem. Would you agree? Anyone know a good source of TA adjustment instructions for a 340? Thanks.
Al L. in Wisc.
06-26-2007 11:57:49
 Re: TA linkage adjustment on a 340U in reply to PaulW_NJ, 06-25-2007 20:37:29
CLLAAAAA AANNNGG you have e/m.
georgeky
06-25-2007 20:47:38
IT service manual will have everything you need to know. It is very important to get the book as these do have to be adjused exactly by the book.
