pto seal 706
RandyWi
06-26-2007 20:18:14
still chasen leaks on this thing,,,
is it possible to just pull rear cover off of pto housing or does whole unit have to be removed to do this? got all the bolts out and got cover about a 1/2 inch away but thats as far as it goes.... desperate need of changing the 540 seal!! please help!!!
Thanks,
Randy
Owen Aaland
06-26-2007 23:00:15
 Re: pto seal 706 in reply to RandyWi, 06-26-2007 20:18:14
The PTO unit must be removed from the tractor first before trying to separate the the castings. The PTO clutch assembly is mounted on the front of 1000RPM shaft and there is a heavy spring to return the clutch piston that is held on that shaft by a snap ring. This clutch assembly must be removed from the front of the PTO assembly before the rear casting can be removed.
