3414 loader tractor brakes
Boblang
06-27-2007 10:54:27
How hard is it to put new brakes in a 3414 tractor
thanks
FromJB2
06-27-2007 17:57:32
 Re: 3414 loader tractor brakes in reply to Boblang, 06-27-2007 10:54:27
Hi Boblang, have done the ag version B414. Required about 1 hour per side. On B414 had to remove hand brake mounting assy. You have to clean the ramp and rollers and lightly lube with a powdered grease. Next check to see if the new disk fit inside the worn metal braking surfaces or do they ride up on the the outside ridges? If they ride up on the outside ridges, you have two options: 1)have the metal braking surfaces ground down
OR 2)Grind a little off the outside diameter of the new brake rotors to fit inside the worn metal braking surface.
JimB
