what is the number one cause of this?
aaron nadolson
06-27-2007 13:27:19
I replaced flow control spring and seal on hydraulics, added fluid to proper level, started tractor, worked for a minute and then lost all hyrdaulic pressure on a farmall 300 utility with power steering. What is the most likey cause? How do I fix it. Thank you!
Dave_Id
06-27-2007 16:25:25
 Re: what is the number one cause of this? in reply to aaron nadolson, 06-27-2007 13:27:19
Bleed the air out of your system
aaron nadolson
06-27-2007 18:16:02
 Re: what is the number one cause of this? in reply to Dave_Id, 06-27-2007 16:25:25
Thanks! I will give it a shot.
