M axle seal
J. Brock
06-27-2007 18:28:18
Where can a guy find a outer seal and the axle {rh side} for a 47 M? Or can the axle be repaired?
rockerscraper1
06-27-2007 18:52:46
 Re: M axle seal in reply to J. Brock, 06-27-2007 18:28:18
can an axle can be welded and turned on a lathe?
georgeky
06-27-2007 18:57:25
 Re: M axle seal in reply to rockerscraper1, 06-27-2007 18:52:46
I welded one up that had the key way broken on it and ground it back down to work. So far it has held. I don't know what is wrong with his.
John M
06-27-2007 18:49:20
Napa, its in the books, or was last week.
georgeky
06-27-2007 18:32:42
The seal is available from IH, I don't know about the axle. You may have to hunt in salvage yard for it. What is wrong with your axle?
J.Brock
06-28-2007 18:07:12
 Re: M axle seal in reply to georgeky, 06-27-2007 18:32:42
The axle has groves worn in it from the seal housing cause the bearing was shot. The seal housing may even be bad,but I havent cleaned it up real good yet to see.
lawmar
06-27-2007 19:47:47
Buy from Ih means pay much more than NAPA.
Brad in WI
06-28-2007 03:06:03
 Re: M axle seal in reply to lawmar, 06-27-2007 19:47:47
Not always! I recently purchased axle bearing from my local CIH dealer and they were cheaper than what I could get them for at my local carquest store. I also get a better deal on parts there than the average customer. I have never dealt with Napa or such cause with living in the city the don't know much about tractor parts.
