F14 Fuel Pump Pushrod length
Kron
06-27-2007 20:27:43
Does anyone have the length measurement of the fuel pump push rod on a 1939 F14?
I understand that the length is critical, and this MAY be part of the reason we aren't getting fuel up to the carb.
Thanks,
Ron
Andy Motteberg
06-28-2007 17:49:42
 Re: F14 Fuel Pump Pushrod length in reply to Kron, 06-27-2007 20:27:43
It should measure 7 inches. Check for wear on each end of the rod also, that can stop it from pumping correctly.
John M
06-28-2007 03:09:33
I dont see how that could be a problem with it not getting fuel unles its extremely wore out or has somehow broke. If that is suspect, I would remove the little oblong cover and check to make sure the linkage is still hooked up.
Ed Topel
06-27-2007 21:11:46
I have one laying here that shows a little wear on the ends and measures 6.992 long. I would guess it was an even 7 inches when new. hope this helps, Ed
