Manifold Paint
Thomas D Windso
06-27-2007 21:07:11
I have not had much luck with paint on the manifold. Is there something that I can put on there to keep it from rusting that will not burn off???
TW
rumplestiltskin
06-28-2007 09:20:53
 Re: Manifold Paint in reply to Thomas D Windsor, 06-27-2007 21:07:11
Thomas:
I’ve been wondering the same thing. My current plan is to buy some exhaust manifold coating from J.C. Whitney. The stuff they sell needs to get hot to cure.
Does anyone out there have any experience with the J.C. Whitney stuff or any comments about it?
Mark W. in MI
Paul Shuler
06-28-2007 08:50:12
Hi Tom, when I did mine I cleaned it up the best I could with a wire wheel and painted it with hi temp manifold paint. I bought it at O'rielys but I have since seen it a Walmart. It has been on there for more than 5 years and still looks just like in the photo. I was surprised it worked so well. And I have plowed and also pushed lots of snow with this tractor and it still has not burned off. A neighbor or mine made me a stailess pipe that goes from the muffler to the manifold. It still looks great and I think that pipe would be very hard on paint.
Paul
Paul Shuler
06-28-2007 08:53:34
 Re: Manifold Paint in reply to Paul Shuler, 06-28-2007 08:50:12
I should have posted this photo. It shows the pipe my neighbor made me.
Paul
rockerscraper1
06-28-2007 03:17:51
sandblast then vht high temp spray bombs
James22
06-28-2007 10:58:35
 Re: Manifold Paint in reply to rockerscraper1, 06-28-2007 03:17:51
Yes, VHT is the best product unless you are going to send to someone whom can refurbish cast iron bathtubs/sinks and therefore can porcelain coat it.
tractor man
06-27-2007 22:32:28
Try this- http://eastwood.resultspage.com/search?p=Q&ts=custom&w=manifold+paint
GordoSD
06-27-2007 21:58:20
Tom, See you are getting info for the manifold. It's been polished but not blasted, knocked off all the horrible original casting flaws and scale. So there is rust in the pores. So bead blast or sand blast to get that out. I used to have access to shot peening which really is the cat's meow, relieves all stresses and makes for ten lifetimes wear. Looks so good you HATE to paint it. No paint on a manifold is forever. But get the rust out and you are way ahead of the game. Use a 'metal prep'on the pipe as it's not cast. Polish as desired priot to that.
Gordo
Bob Kerr
06-27-2007 21:23:46
This is something that is awsome! DGF (dry graphite film)spray. looks like bare cast iron but is not paint so it can't burn off. you would have to get the manifold red hot to burn this stuff off. You can get it at most NAPA stores. I have used it on race headers, my ol 10-20 manifold, on show car manifolds, and on my WOOD STOVE and it looks great, BUT you will have to reapply it once in a while. It is not water proof so if you wash the tractor you might have to touch it up. I have wasted good money on so called heat proof paint and they all failed miserably, DGF really takes the cake. If you lightly buff it with a rag it gets shiny! Kind of expensive, but a little goes a long way and it should last you for years.
