Order Farmall Cub Parts Online
Cub PTO disengaging question
AlexLV
06-28-2007 11:28:31
Does it hurt to disengage the PTO on a Cub while the clutch is still engaged?
Janicholson
06-28-2007 14:29:46
 Re: Cub PTO disengaging question in reply to AlexLV, 06-28-2007 11:28:31
If it is not under load at all (no load on PTO) it is OK. If loaded at all it will wear the teeth on the dog clutch that controlls off and on. The repair is not nearly as easy as clutching the tractor. An additional concept is that the moving tractor will also drive the PTO (at least to an overrunning clutch used for bushhogging) so letting the tractor stop befor shifting out is best. JimN
