Problems
IHCM
06-28-2007 11:37:55
Hey guys, I went out to start the ol' M and when I hit the starter it did not turn over. What it did do, is made a humming noise. The noise stopped when I let off the starter. I went to try it again and now I have nothing. Whats the problem? Thanks
old
06-28-2007 15:15:30
 Re: Problems in reply to IHCM, 06-28-2007 11:37:55
As George says check out the battery cables etc. Any one or all of them could be the problem
neblinc
06-28-2007 13:28:53
Easy enough to remove the bolts holdin the starter to see if the starter drive is hung up.
Randy
georgeky
06-28-2007 11:54:52
It could be one of several problems. I would start by checking all connections at the battery and starter. Could be as simple as a low or dead battery. Could also be a bad starter. Could be that mice have built a nest in the bell housing and the starter drive gear is locking up on the ring gear. I would check those cable connections and go from there.
