Main drive shaft question for Bob Kerr
SLH IN MO
06-29-2007 05:27:19
Bob does the transmission have to be in gear or will neutral do . I'm tring to do this without taking the transmission cover off .THANKS
Bob Kerr
06-29-2007 20:08:06
 Re: Main drive shaft question for Bob Kerr in reply to SLH IN MO, 06-29-2007 05:27:19
JimN is right, When I took out my driveshaft I already had the rear axle out and the brakes removed so I kind of had a whole different can of worms to deal with. I had to have someone hold the gears still with a block of wood when I needed them to stay put.
Janicholson
06-29-2007 07:37:03
If you are into the input shaft carrier and not just the clutch shaft, the top (or at least the belt pulley needs to come off to catch the bearings. Neutral helps move things for access. In gear helps remove nuts. (assumes an H or M W/O TA.) JimN
