How to remove the precleaner on a 340?
Gary Schafer
06-29-2007 09:42:19
I have a Farmall 340 that I need to take the hood tin off of. How do you get the air precleaner off the inlet pipe that goes thru the hood?
Thanks!
Gary
Gary Schafer
06-29-2007 15:20:52
 Re: How to remove the precleaner on a 340? in reply to Gary Schafer, 06-29-2007 09:42:19
Ok, I got it off. Used a hammer around it and it came of without too much trouble. Thanks for the replies.
The plastic cup has a chunk missing from it though. Does anyone have that part or a whole pre cleaner they want to part with?
Thanks
Gary
Wardner
06-29-2007 10:52:29
If you are talking about the plastic cyclone bowl and associated metal parts, it was pushed on by hand. You should be able to pull it off the same way. If not you will have to use a persuader and maybe a block of wood. I have several pre-cleaners and have not had a problem. I got into some brush the other day and a small branch lifted my pre-cleaner.
Gary Schafer
06-29-2007 12:16:19
 Re: How to remove the precleaner on a 340? in reply to Wardner, 06-29-2007 10:52:29
This one looks like it was pressed on. The metal part of it looks like pot metal or cast aluminum and is very tight on the pipe. I wonder if a little heat might help?
Thanks for your help.
Gary
Nat 2
06-29-2007 12:27:35
 Re: How to remove the precleaner on a 340? in reply to Gary Schafer, 06-29-2007 12:16:19
Use a firm twisting/lifting motion to break it free and work it off.
There is no doubt that it was just put on there by hand. It's an aftermarket precleaner, and they certainly didn't haul the tractor to a machine shop to have the precleaner pressed on :)
More than likely, there's been a little corrosion between the pot metal (maybe aluminum?) and the pressed steel air cleaner standpipe.
