300 hydraulics leaking
mtb300
06-29-2007 12:10:45
My 300 is leaking hy-tran fluid from where the tach cable connects under the distributer, right in front of the hydraulic pump . Any ideas on how to fix this problem? Thanks.
alex ahlbrecht
06-29-2007 14:21:06
 Re: 300 hydraulics leaking in reply to mtb300, 06-29-2007 12:10:45
good luckthird party image
mtb300
06-29-2007 12:51:41
Thanks guys, I'll have to order some seals for it. I have the all the sheet metal off the tractor anyways,needs a TA and other maintenance items, and paint. Only had it a year. Things add up quick for a college kid though.
alex ahlbrecht
06-29-2007 12:44:30
definatly put new seals in it then
mtb300
06-29-2007 12:30:11
I filled the reservoir and was cutting a pasture with it and in about two hours all but about a quart had leaked out.
alex ahlbrecht
06-29-2007 12:25:42
 Re: 300 hydraulics leaking in reply to georgeky, 06-29-2007 12:10:45
georgeky said: (quoted from post at 20:17:04 06/29/07) If it is leaking there is only one solution. Take the pump off and install new seals in it.
do that^^
and how bad is it leaking?
georgeky
06-29-2007 12:17:04
