Should I split my 1486?
Francisco.
06-29-2007 12:25:04
Two years ago I fixed the clutch, replace the set.Since then tractor was working fine. Last six months tractor was sitting because my dad illness. I just started it and did fine but when I tried to moved it couldn't place the gear, none of them either forward or reverse, gears making sound.
Checked underneath in the window and see that fork is moving and bearing as well but also was able to see there is an oil leak which which is trans oil.
Could it be that clutch is not being released? because springs? should I split tractor to repair clutch? or could it be that problem is from another source?
Your help will highly regarded.
FromJB2
06-29-2007 14:03:37
 Re: Should I split my 1486? in reply to Francisco., 06-29-2007 12:25:04
After sitting for 6 months, clutch disk is probably stuck to flywheel and/or pressure plate.
One way to loosen clutch is with tractor turned off, wheels blocked and brakes on put transmission in high gear, CLUTCH DEPRESSED, LEAVE FUEL SHUTOFF IN OFF position and bump the starter a couple of times and clutch should brake free.
JimB
Francisco
06-30-2007 20:03:43
 Re: Should I split my 1486? in reply to FromJB2, 06-29-2007 14:03:37
Tahnks a lot JimB I will try once I'm back to place where tractor is.
