SERIAL NUMBER
ELVIN C FRANK
06-29-2007 19:12:12
the serial number on my SUPER M is L-504525 there is alson the leters AJ after the number, can anyone tell me what year this tractor is? Thanks in advance
CNKS
06-29-2007 19:47:30
 Re: SERIAL NUMBER in reply to ELVIN C FRANK, 06-29-2007 19:12:12
If it has a starting tank, or a hole in the right rear corner of the hood, A means it has a distillate engine, a little unusual for a Super M, but distillate engines were available through 450 production. J means it has a Rockford clutch, as nearly all of them do. The Super M has a high speed 4th standard. For the M, not the Super M, X1J means gasoline engine, high speed 4th, 5000 ft altitude pistons.
georgeky
06-29-2007 22:20:12
 Re: SERIAL NUMBER in reply to CNKS, 06-29-2007 19:47:30
I looked again and you are right. I was looking right at M codes. I thought it was strange when L should have meant the three things I mentioned.
elvin c frank
06-29-2007 21:04:09
is it a 4 speed transmission or 5? what is the gear pattern, i could not find but 4 holes where it would fall in and i was told it had a 5 speed
georgeky
06-29-2007 22:25:23
 Re: SERIAL NUMBER in reply to elvin c frank, 06-29-2007 21:04:09
Unlike my other post. It is a 5 speed in a standard H pattern for 2 thru 5 and 1st and reverse are opposite one another. All the way to the left and up is reverse If it was ordered with steel wheels it may have 5th locked out. I don't know if that was done on these or not.
elvin c frank
06-29-2007 20:56:49
what is a distallite engine, is that good, bad, or ugly, i'm typically a ford 9n guy i don't know much about farmalls past the fact they are red lol
georgeky
06-29-2007 20:22:53
I may need to throw my chart away. That is were the info I posted came from. Sorry
georgeky
06-29-2007 19:34:17
A is for low low gear and J is high speed 4th gear and 5000 foot pistons. That make it rarer than everyday Super M. It was made in Louisville.
D Slater
06-29-2007 19:58:08
 Re: SERIAL NUMBER in reply to georgeky, 06-29-2007 19:34:17
1953, A = Distillite engine, J = Rockford clutch as originaly sold.
landlord7012
06-29-2007 19:23:40
on the left click on "serial number". Looks like Lousville 1953. Not sure about "A". "J" should be Rockford clutch. How did I do guys?
ll
Andrew Z
06-29-2007 19:27:51
 Re: SERIAL NUMBER in reply to landlord7012, 06-29-2007 19:23:40
I belvie the A is for a distalate engine not the high compression gas.
Andrew
